Date/Time: Wed, 25 Nov 2026 21:45:56 +0000
Recreate a 2 Target Break-Even Stop on my bracket (it was deleted)
View Count: 703
[2025-05-12 14:53:55]
MSanders - Posts: 1
I accidentally deleted the 2 Target break-even bracket setup on my DOM's pre-set bracket configurations. Can I get that back, please? I've been trying to find a work around by recreating other saved configurations. But, I would still like it back.
In trying to recreate what I need, I have had a problem inputting any values into the auto-breakeven ticks triggered value. I at first thought this was a problem because I deleted the 2 Target break-even bracket, but now I find it takes 7, so it is probably just a problem on my end. Would you mind clarifying that.
[2025-05-12 18:14:46]
Check the "Backups" folder under your main Sierra Chart installation folder and see if there is a backup of that trade configuration in there. Those files have a file extension of '.twconfig'.
You will need to copy the file from the "Backups" folder to the "Data" folder, which is also under your main Sierra Chart installation folder. You can rename it as you want, but the extension needs to stay the same (.twconfig).
