Date/Time: Wed, 25 Nov 2026 21:46:14 +0000
sierrachart.h
View Count: 2476
| [2025-05-11 20:39:29] |
| User108811 - Posts: 14 |
does anyone know how to update or download sierrachart.h i'm having trouble compiling codes doesn't recognise sc.GetStudyArrayFromChartUsingID.
| [2025-05-11 22:35:11] |
| ForgivingComputers.com - Posts: 1256 |
It is part of the Sierra Chart update. What version are you running?
| [2025-05-12 00:00:29] |
i'm sunning version 2757 but it doesn't update the sierrachart.h file
| [2025-05-12 00:02:00] |
i'm running version 2757 but it doesn't seem to update the sierrachart.h file
| [2025-05-12 00:52:39] |
| Sierra_Chart Engineering - Posts: 25483 |
The latest SierraChart.h file is in the /ACS_Source folder in the Sierra Chart installation folder. To update Sierra Chart to the latest release, refer to: Software Download: Fast Update Do you see this line at the top of the file: #define SC_DLL_VERSION 2755 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2025-05-12 00:53:10
| [2025-05-12 01:18:03] |
Not every update changes the SierraChart.h file. |
