Date/Time: Wed, 25 Nov 2026 21:46:17 +0000
Can I Combine Depth for Recent Bid/Ask, Not for Pulling/Stacking?
View Count: 780
| [2025-05-10 01:08:26] |
| User261655 - Posts: 57 |
Is there a way to combine market depth data for the recent bid/ask column, but leave the pulling/stacking column in 1-tick increments? (The 1-tick pull/stack visualization works better for me). I only see the all-or-nothing option: "Apply Combine Increment in Ticks to Other Market Data Columns." Alternatively, could I roll back to some previous version where "combine recent bid/ask" was an option that didn't affect pulling/stacking? Thanks, as always! |
| [2025-05-12 13:43:41] |
There is not an option to control the combining of the volume data in individual columns. As you state, it is all or nothing. You could roll back, as the combining of the Pulling/Stacking was not too long ago. The combining of the pulling/stacking was introduced around version 2754, so you would need to try a version prior to that (you may need to go back a few releases). But, eventually you will need to move to a current release, just due to changes we continue to make. We have noted your request, although we can not say when we will get to any particular item. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
