Date/Time: Wed, 25 Nov 2026 21:56:06 +0000
Custom Study Compiles but Not Recognized or Executed in Chart Replay Mode
View Count: 792
[2025-05-09 00:25:00]
User867930 - Posts: 8
Hello Sierra Chart Support,
I’m encountering a persistent issue when developing and compiling a custom study (VectorAI) using ACSIL. The study compiles successfully from the ACS_Source directory and appears in the list of available studies. However, when added to a chart and run in Chart Replay mode:
No trades are executed
No trade activity is logged
No markers are displayed
The Trade Activity Log and Trade Orders windows remain blank
Here’s what I’ve confirmed so far:
Study compiles with no errors using Visual C++ release build
sc.AllowOnlyOneTradePerBar and sc.MaintainTradeStatisticsAndTradesData are set to true
All auto trading settings are enabled: Global, Chart, Simulation Mode, and Chart Trade Mode
Chart Replay Mode is properly set up and active
The chart displays the signal overlay (e.g., SMA) correctly
Symbol used is ESM25 with a valid chartbook and data loaded
Trade simulation settings are properly configured
Tick size, quantity, and order structure are verified
All Chart Settings (Trading tab) and Global Settings are correctly configured
I’ve even tested different file names (e.g., MinimalPlaybackTest.cpp) with identical code, and sometimes it works once, then fails under the same setup.
Could you help us determine why the compiled strategy fails to trigger trades or register any simulation activity during replay?
Thank you for your help.
Paul Strickland
Ironbeam User – Teton Order Routing Enabled
Live feed authorized (awaiting real-time confirmation)
attachmentVectorAITestPlayback.cpp - Attached On 2025-05-09 00:17:53 UTC - Size: 1.89 KB - 359 views
[2025-05-09 09:22:05]
This is not within the scope of our support.
We would recommend doing debugging:
Step-By-Step ACSIL Debugging
Date Time Of Last Edit: 2025-05-09 09:22:14
[2025-05-09 09:23:40]
User431178 - Posts: 910
The code in VectorAITestPlayback.cpp does not compile, it has the same problem as the code in your other post - Custom Study Compilation Fails —
The attached modified code compiles and works.
I added notes into the code too show what is different.
attachmentVectorAITestPlayback.cpp - Attached On 2025-05-09 09:22:53 UTC - Size: 2.4 KB - 416 views
