Date/Time: Wed, 25 Nov 2026 21:46:16 +0000
Ho do I set Daily Volume profile besides Volume Traded
View Count: 800
| [2025-05-08 20:38:38] |
| User246156 - Posts: 6 |
Hi guys. Thanks in advance for your help. You have been fantastic! My question is, if it is possible to separate VOLUME PROFILE from VOLUME TRADED so they don't overlap. I use Market Profile and for reference I am attaching a picture in which you can see how thanks to your help I separated them in NUMBER BARS study, but I cannot do the same with my MARKET PROFILE chart. As you can see in the NUMBER BARS study, it is better that way. |
| Attachment Deleted. |
| [2025-05-09 18:47:11] |
The Volume Profile does not have an option to put the numbers where you are wanting. Refer to the following Input for the options that are available: Volume By Price Study: Align Volume Numbers to Base of Volume Bars For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2025-05-09 20:02:35] |
OK Some else I forgot to ask the first time. Is it possible to place the volume profile at the left side of TPO Market Profile? |
| [2025-05-09 21:40:30] |
The Volume Profile is always to the right of the TPO, or on top of it. There is no support for having it on the left.
