Date/Time: Wed, 25 Nov 2026 21:46:15 +0000
Brackets in attached stop-loss live order
View Count: 809
| [2025-05-08 11:53:36] |
| User251043 - Posts: 50 |
Hi, When trading live (Teton CME routing) I send an attached stop-loss with each order. When the order is filled, the stop-loss order appears as in the image. What is the price in brackets? The maximum slippage I will accept? When trading in the Evaluator I don't see the brackets. A couple of questions: 1- How can I modify the quantity in brackets? 2 - And, most important, how can I remove the brackets from the chart? I want to see the stop-loss price but I don't want to see the brackets (even if that maximum slippage is still working). In the image, I want to keep the 5697.00 and the 1 (quantity), but I want to remove the (5692.00) Any help would be appreciated. Thank you. |
| Attachment Deleted. |
| [2025-05-09 13:40:00] |
| Sierra_Chart Engineering - Posts: 25483 |
We think you are referring to the limit price of a stop limit order. When you submit a Stop order on the CME it is converted to a stop limit order. We will check to see if that limit price can be removed and if not we will add an option for it. You can modify the quantity of the order following the instructions here: Chart Trading and the Chart DOM: Changing Order Quantity Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2025-05-10 09:04:29] |
Thank you, I wasn't aware of the conversion Stop->Stop Limit by CME. Thanks. What I need is exactly what you said: "We will check to see if that limit price can be removed and if not we will add an option for it." I want to remove that limit price from the chart. In Chart Trade Settings there's the option for displaying "Order Price" (Yes/No), but it removes the price and the limit price. An option to display or not just the limit price in Stop-Limit orders would be super. Thank you again. |
