Date/Time: Wed, 25 Nov 2026 21:56:20 +0000
PNL not showing
View Count: 535
| [2025-05-07 20:27:20] |
| p.a.c. - Posts: 3 |
hi there, my open positions pnl and daily pnl do not show in this page. they stay at zero the whole day. why is that? and how do i see my starting balance at begning of day and end? thanks https://www.sierrachart.com/Download.php?Folder=TicketingSystem&download=120339 |
| [2025-05-08 02:12:19] |
| Sierra_Chart Engineering - Posts: 25483 |
We see you are using CQG and those fields are not supported with CQG. Use Teton order routing for support for those: Sierra Chart Teton Futures Order Routing Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
