Date/Time: Wed, 25 Nov 2026 21:56:18 +0000
Vol at Price Threshold Alert V2
View Count: 582
| [2025-05-07 20:15:40] |
| Crtfyd - Posts: 310 |
With Vol at Price Threshold Alert V2 setting the "threshold" will give us the threshold or greater. But how can I get a threshold or LESS? ( Example: I want a level that has LESS than 100 Bid? ) Thank you |
| [2025-05-08 02:14:35] |
| Sierra_Chart Engineering - Posts: 25483 |
You need to modify the study to meet your requirements: How to Build an Advanced Custom Study from Source Code Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
