Date/Time: Wed, 25 Nov 2026 21:56:22 +0000
2nd instance data freeze
View Count: 615
[2025-05-07 12:01:38]
ElsonJr - Posts: 9
Hi, the data on my 2nd instance froze after I changed my Data/Trade service to Teton CME Routing on my first instance. My first instance data is working fine after the change however my 2nd instance data freeze upon changing. Please help
[2025-05-07 12:25:12]
MTScalper - Posts: 35
Did you check if the symbols are compatible? If your second instance was using a different data feed than the one you’re currently using on the main instance, you’ll need to reload the symbols. Alternatively, you can simply go to *Chart Settings → Symbol (Action)* and reload the symbol with the new feed on the second instance.
[2025-05-07 12:50:48]
ElsonJr - Posts: 9
Hi yes both symbols are ESM25-CME. I tried reload symbol with the new feed but it is still the same.
[2025-05-07 14:19:28]
ElsonJr - Posts: 9
Hi it is working now.
What i Did
Edit>Translate symbols to current service
thank you
