Date/Time: Wed, 25 Nov 2026 21:56:25 +0000
Number bar Bid/Ask Bold Threshold not working
View Count: 564
| [2025-05-07 02:56:10] |
| gaoxxxx - Posts: 28 |
I have two GPUs, one is intel one is NV. Is there problem in setting OpenGL? I have tried both but not working.
| [2025-05-08 12:44:20] |
| Sierra_Chart Engineering - Posts: 25483 |
Is the issue that you are not seeing the text being bolded. Usually this is the result of a particular type of font which is being used. Also try disabling OpenGL and see if it resolves the problem. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2025-05-08 12:44:39
