Date/Time: Wed, 25 Nov 2026 21:56:03 +0000
Question on custom task bar
View Count: 536
| [2025-05-06 19:10:28] |
| victoria - Posts: 2 |
I have my custom taskbar which is detached from my Sierra graphic, and I can no longer find it, how do I proceed? (original) Merci pour votre réponse , également j’ai ma barre des tâches personnalisées qui est détachée de mon graphique Sierra , et je n’arrive plus à le retrouver, comment procéder ? Date Time Of Last Edit: 2025-05-06 19:10:49
| [2025-05-08 12:49:48] |
| Sierra_Chart Engineering - Posts: 25483 |
We think you are referring to a Control Bar. Refer to: Control Bar: Unable to Make Control Bar Visible Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
