Date/Time: Wed, 25 Nov 2026 21:56:02 +0000
not play replay mode properly
View Count: 567
| [2025-05-06 17:35:48] |
| kaushal_jayamaha - Posts: 1 |
Dear Sierra chart , I am experiencing an issue with the replay mode feature. When I press the play button with replay mode enabled and specify a start date (for example, 2025/03/01), the replay mode consistently starts on 2025/05/01 instead. This happens regardless of the date I enter; the replay always begins on May 1st, 2025. I am unsure why this is occurring. Could you please provide some insight or guidance on how to resolve this problem? Thank you for your time and assistance. Sincerely, K |
| [2025-05-07 07:31:42] |
| Sierra_Chart Engineering - Posts: 25483 |
This is because that date you want to start the replay at most likely does not exist in the chart. To load more data in an Intraday chart: Historical Intraday Data (Missing Data / Download Errors / Viewing More Data): Downloading/Viewing More Historical Intraday Data Refer to the instructions here: Replaying Charts: Basic Chart Replay Instructions Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
