Date/Time: Wed, 25 Nov 2026 16:50:52 +0000
[Programming Help] - error code C2062, C2143 & C2447
View Count: 720
| [2025-05-06 15:18:33] |
| User108811 - Posts: 14 |
can anyone help, i'm trying to code on C++ but i keep getting these errors above: #include "sierrachart.h" SCDLLName("Test_Compile_Check") SCSFExport void scsf_TestCompileCheck(SCStudyInterfaceRef sc) { if (sc.SetDefaults) { sc.GraphName = "Test Compile Check"; sc.AutoLoop = 1; sc.GraphRegion = 0; return; } // No processing logic - this is just a stub for testing compile } |
| [2025-05-06 15:42:34] |
| User431178 - Posts: 910 |
Are you sure that sierrachart.h is being found correctly? Where/how exactly are you building your code? |
| [2025-05-06 16:00:03] |
not sure if sierrachart.h is being found correctly. i'm using Notepad++ |
| [2025-05-06 16:35:39] |
I just noticed what it is... This is wrong: SCSFExport void scsf_TestCompileCheck(SCStudyInterfaceRef sc) Should instead be: SCSFExport scsf_TestCompileCheck(SCStudyInterfaceRef sc) SCSFExport is a macro that sets the return type for the function, amongst other things, so your "void" is not needed. |
| [2025-05-06 19:06:07] |
Thank you that worked. I was stuck here for 2 days :(...
