Date/Time: Wed, 25 Nov 2026 21:55:54 +0000
Historical Intraday Data Problem
View Count: 1185
[2025-05-06 11:44:48]
Betoune89 - Posts: 6
Hello, I'm having a problem downloading intraday historical data, apparently an authorization issue but I don't understand why. Here's the exact message:"Histrtorical Intraday Data Download Failed Error downloading historical intraday data for ESM5.CME permission denied" Thank you for your help.
screenshot:https://www.sierrachart.com/Download.php?Folder=SupportBoard&download=120254
imageCapture d’écran 2025-05-06 132137.png / V - Attached On 2025-05-06 11:28:38 UTC - Size: 60.95 KB - 428 views
[2025-05-06 20:00:44]
You are using the Denali Exchange Data Feed so you should not be getting that error.
We want you to restart Sierra Chart.
And:
Set "Global Settings >> Data/Trade Service Settings >> Common Settings >> Allow Support for Sierra Chart Data Feeds" to Yes. If you have changed this setting, then reconnect to the data feed after by selecting 'File >> Reconnect".
After that:
Re-download all the data in the chart by going to the chart and selecting "Edit >> Delete All Data and Download" from the main Sierra Chart menu. You just need to do this once per symbol and not for each chart. This command is on the main Sierra Chart menu at the top. Only use it from that location.
Date Time Of Last Edit: 2025-05-06 20:01:03
