Date/Time: Wed, 25 Nov 2026 21:56:06 +0000
Confirming Whether its Possible to Create a Custom Drawing Tool
View Count: 883
| [2025-05-06 02:15:18] |
| User920737 - Posts: 9 |
I wrote two programs which imported successfully as indicators but I do not see an option to use them as a custom drawing tool. I created a Fib tool and changed the parameters in how it calculates it levels from the original so they would be based off risk multiples of my Stop value. Stop value was defined as the first point marked on the chart and entry value was the second point. Then if it plotted correctly the horizonal levels would show 1.5R, 2R, 3R levels etc. The original tool bases its risk off the 0 level. Can you import scripts as custom drawing tools? If not, is there a way to use the template of an existing drawing tool and override its functionality with additional functionality using a script? If so, how would I accomplish this task? |
| [2025-05-06 19:41:07] |
| Sierra_Chart Engineering - Posts: 25483 |
You can create an ACSIL function that does support interaction with the system pointer and create Chart Drawings. Refer to: Advanced Custom Study Interaction With Menus, Control Bar Buttons, Pointer Events Using Drawing Tools From an Advanced Custom Study Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
