Date/Time: Wed, 25 Nov 2026 21:56:02 +0000
Open/gl. Ability to have turned on/off for individual charts?
View Count: 1127
[2025-05-05 06:03:44]
User136282 - Posts: 14
Seems like im stuck with global control either on or off for all the charts when it comes to openGL. I would like to only use openGL on certain charts, is this possible? So I got global openGL turned on, then try and shut it off on individual charts, but the individual chart has use openGL for chart graphics checked and greyed out, even tho the use global graphics setting for said chart is unchecked. Ive also tried doing it vice versa and shutting off global g/L and turning it on for each individual chart, but ran into a similar issue of the box being greyed out where i would normally check to turn on open/GL.
[2025-05-05 08:13:25]
This is not possible to do.
