Date/Time: Wed, 25 Nov 2026 21:56:00 +0000
Trailing stop lines
View Count: 677
| [2025-05-04 06:18:10] |
| User684034 - Posts: 25 |
Hello, please is it possible to see the trailing stop "line" on chart... And move it by drag up or down? Thank you |
| [2025-05-05 15:36:38] |
If you are wanting to see a line where the stop will move to when it starts trailing, then there is no direct support for this. You could always create a line to see where this is. You would need to use the Spreadsheet study to do this in order to calculate the line in a way that it only moves up and not back down with the current price. Refer to the following: Using the Spreadsheet Study For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2025-05-05 17:08:02] |
Thank you Mr John, I appreciate your support! But it's too difficult for me! Maybe if you can suggest me a link... Where someone had same idea.... If not... No problems.. Thanks anyway 👋👋
