Date/Time: Wed, 25 Nov 2026 21:56:10 +0000
Put one indicator in the Main Chart
View Count: 716
| [2025-05-03 22:21:53] |
| User296553 - Posts: 21 |
I've been wanting to put the indicator Ask/Bid Volume Difference Bars inside the main chart of CHART REGION 1, I've also set it into independent. It shows but it's too small for me to see, how to do it right? |
| [2025-05-05 15:31:53] |
You are really better off having that in a separate region. You can remove region lines and the data displayed so it will look like it is part of the same region. But, if you want to keep it in the same region, then the best way to get it how you want is to set that study to use the "Left Side Scale" and then turn on the left side scale to adjust it how you want. You can then turn off the left side scale when you have it as you want it, if you do not want to continue to see the left side scale. Refer to the following: Chart Settings: Use Left Side Scale (Chart >> Chart Settings >> Scale menu) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
