Date/Time: Tue, 17 Nov 2026 18:08:56 +0000
Cumulative volume delta on historical chart
View Count: 3366
[2025-05-03 17:17:35]
User243905 - Posts: 3
Hello
I have selected historical data from Sierra Chart.I have a problem to display cumulative volume delta on historical chart because every time when I chose CVD indicator I see the message "this study can only be applied to an intraday chart". Can you advice how I can have CVD on historical chart
Thank you
Wojtek
[2025-05-03 17:58:59]
Sierra_Chart Engineering - Posts: 25432
You cannot. This study can only be used on an Intraday chart.
[2025-05-04 15:28:16]
So for intraday chart how many days back I can see CVD? Is there any limitation to 5 days or so?
Do I need Denali data feed for this?
[2025-05-05 15:50:24]
John - SC Support - Posts: 48555
There is no limitation on how many days you can view the Cumulative Delta Bars - Volume study.
The data you are getting now is our Delayed Streaming Data. This is the same exact data as the real-time data, only delayed. So you do not need anything in particular, unless you are wanting real-time data.
[2026-03-17 16:50:52]
cferry - Posts: 18
For anyone landing here — I built a CVD study that computes delta internally from bid/ask volume, so it doesn't need a separate external study. Draws it as a filled area with separate colors for positive and negative values.
Has 4 session reset modes and you can choose between stair-step or candlestick outline.
https://scstudies.com/products/cvd-filled-area
