Date/Time: Wed, 25 Nov 2026 21:06:05 +0000
Halfback on TPO charts
View Count: 859
[2025-05-02 20:30:35]
Sameh Elgamal - Posts: 15
Is there any possibility to add halfback as shape on TPO charts. The current highlight is not working once you enable Percent Width For Volume Profile the halfback color is not visible anymore. We need a workaround.
imageESM5.CME MESM5.CME[M] #5 2025-05-02 16_26_43.665.png / V - Attached On 2025-05-02 20:30:27 UTC - Size: 185.92 KB - 448 views
[2025-05-02 21:07:09]
John - SC Support - Posts: 48659
We assume you are referring to the "Draw Midpoint in Profile" for the TPO study for the halfback, but we do not understand how changing the Percent Width for a volume profile changes this in the TPO. Please let us know what item exactly you are changing and for what study.
[2025-05-02 21:49:31]
When you select to color the letters based on volume percentage, the letters are colored based on the volume on color letter block 1 to 10. Midpoint color is not used anymore as the color or the volume has priority over the midpoint color. The opening is still visible. Check my image for more info.
[2025-06-13 21:32:38]
We have changed the TPO so that the midpoint TPO will keep its coloring when "Color TPO Row Based on Percentage of POC Volume" is set to "Yes".
This will be in the next Pre-Release (v 2765).
[2025-06-16 05:42:24]
Excellent news. Is there any possibility to highlight the value area on TPO with rectangle similar to windotrader while maintaining the colors as of letters with relation to volume. I am current using VAH and VAL lines however they are not as visible as needed. It would be great if we can highlight the area between the two.
[2025-06-16 14:10:41]
We assume you are referring to when the Input for "Color TPO Row Based on Percentage of POC Values" is set to "Yes", as in this one case the Value Area is not colored.
This is not an easy change, so it's not something that we could get to immediately. As such, we have recorded this as a Feature Request. We can not say when we would get to any particular request.
