Date/Time: Wed, 25 Nov 2026 21:56:08 +0000
scale out not working properly
View Count: 875
[2025-05-02 16:09:20]
Cesium - Posts: 179
scale out scaling out all contracts in a position but one
was in +8 position and scale out sold 7, leaving 1
it is set to scale out 4 and leave 4
started occurring when i switched both targets from LMT to MIT
scale out functions incorrectly on non-simulated with MIT
scale out functions correctly on simulated with MIT
i cannot find a reason
thank you
Date Time Of Last Edit: 2025-05-02 16:31:17
[2025-05-02 18:44:44]
How are you sending the orders? Is this a manual order or are you using some kind of automated system? If an automated system, which one are you using?
[2025-05-02 19:17:02]
Cesium - Posts: 179
Hi John its manual mkt orders via keyboard shortcut
[2025-05-02 19:28:13]
Can you get us an image of the Attached Orders tab on the Trade Window for this setup?
[2025-05-02 19:37:06]
Cesium - Posts: 179
Yes attached
Private File
[2025-05-02 19:49:52]
That configuration is setup for a total quantity of 2. Are you using "Scale In" when you add more orders? Do you have a problem with a quantity of 2 working correctly (do the Targets work properly with just a quantity of 2)?
[2025-05-02 20:08:35]
Cesium - Posts: 179
I dont know if the MIT Targets work properly with a QTY of only 2, I would have to test on live account
attached, and also on Trade Menu -> Menu -> Orders -> Support scale in, support scale out both checked, will try for screenshot
Private File
Private File
[2025-05-02 20:52:33]
We are trying to understand the particular workflow. So you start with a position of 2 and then add on to it 3 more times to have a total quantity of 8, correct?
Then when one of the targets is touched, it should close out a total quantity of 4, but you are seeing a total of 7?
[2025-05-02 21:05:28]
Cesium - Posts: 179
Yes and Yes
[2025-05-02 21:09:32]
Can we get the Trade Activity tab information for a particular situation where this has occurred. Follow these instructions to get us the information:
Trade Activity Log: Providing Trade Activity Log Data Lines to Support
