Date/Time: Wed, 14 Oct 2026 21:05:09 +0000
Rithmic and Sierra Data on different servers
View Count: 1503
| [2014-09-30 16:35:43] |
| User787778 - Posts: 142 |
I run 2 sets Sierra Charts, one on my local machine and one on a VPS in the USA. I have subscribed to Sierra live data and want to run the Sierra data on my local machine, while running my brokers Rithmic data, on the VPS. The problem is that my local machine has frozen and even after restarting Sierra Charts, the computer remains frozen.
| [2014-09-30 16:42:39] |
The "computer remains frozen"? This can have various kinds of meanings. Could you be more specific.
| [2014-09-30 17:17:16] |
The data feed shows that it is connected, but the bars remain static.
| [2014-09-30 18:06:52] |
Please respond it is urgent.
| [2014-09-30 18:40:07] |
Please tell me when you will respond? |
| [2014-09-30 18:56:04] |
We apologize for the delay. We see you are using "SC Exchange Data". In the case of the CME markets you will not get real-time data unless you pay the higher exchange fees, when using that Service. Refer to: http://www.sierrachart.com/index.php?page=doc/SierraChartRealTimeFuturesStockDataFeed.php#CME Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-09-30 19:11:35
| [2014-09-30 19:07:16] |
I thought that if I used a Rithmic trading account, I could run more than one computer with it?
| [2014-09-30 19:11:04] |
No it does not work that way. Let us know if you want a refund for the data feed.
| [2014-09-30 19:26:23] |
Please look at your replies to : "Unable to log onto second computer" dated 2014-05-30
| [2014-09-30 19:39:41] |
Where is this? Is this a Support Board posting?
| [2014-09-30 19:41:12] |
Yes a support board posting
| [2014-09-30 19:43:57] |
OK, we found it: Unable to log on to second computer What is the point? We see nowhere where it says that you can use SC Exchange Data to access real-time CME data. Since you are using Rithmic , connect your Rithmic account and make sure your broker allows 2 simultaneous connections. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
