Date/Time: Wed, 25 Nov 2026 21:56:06 +0000
[User Discussion] - Options intraday data
View Count: 748
| [2025-05-02 12:32:50] |
| User562146 - Posts: 1 |
Hello, I'm new to sierrachart, I actually have an options strategy that I want to backtest, I use the native data provider "SC data". I can load future expired contract without problem on "historical data" and "intraday data", but for expired options I can load them only on "historical mode", when I try the "intraday" mode the chart appear but stay black. So my questions are : Is it possible to load intraday data on expired options ? If yes, how to do it and having 1 tick bid/ask price data ? If not, do you have a solution to advise me (data provider for sierrachart) ? Thanks in advance ! |
| [2025-05-05 19:32:04] |
| Sierra_Chart Engineering - Posts: 25483 |
Yes: Is it possible to load intraday data on expired options ? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2025-05-05 19:32:11
