Date/Time: Wed, 25 Nov 2026 21:55:53 +0000
Chart in Charbook scaling issue
View Count: 568
[2025-05-01 10:34:33]
bodzhar - Posts: 19
Something happened in my chartbooks where I am unable to get them display at 100% no matter how I resize the charts or chartbook. I am having to use to use the scroll bar on the side to move up and down to see all the charts. I am not sure how this came about? Are you able to tell me what the problem is?
I tried copying the charts to a new chartbook but same problem but if add new charts instead, no scaling problem. This problem affects all my open chartbooks
imagechartscale.png / V - Attached On 2025-05-01 10:32:15 UTC - Size: 442.11 KB - 342 views
[2025-05-01 14:05:36]
Make sure the scale is set to "Automatic" and then reset the scales. Refer to the following:
Chart Scale and Scale Adjusting: Automatic (Scale Range)
Chart Scale and Scale Adjusting: Resetting the Scale
