Date/Time: Wed, 25 Nov 2026 21:56:00 +0000
Sierra Chart - different study results / SC data vs Rithmic
View Count: 628
| [2025-05-01 08:24:02] |
| stefkovic.m28 - Posts: 45 |
Hello, is it normal or possible, that the study results from volume price study and others are getting me different values? See my attached screen where I have compared SC data values with the Rithmic values for the same study + same time period. The OHLC values are the same, but why Sierra calculate other values for the same study? Which data should I then use for the backtest? thanks |
| [2025-05-01 13:58:29] |
This goes to show the differences in the underlying data between the data feeds. There are some places where at least the Ask and/or Bid volumes are different. We stand behind our data and that it matches what the exchange sends. This has been tested and verified many times. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
