Date/Time: Wed, 25 Nov 2026 21:55:54 +0000
canceling only non-attached orders
View Count: 593
| [2025-04-30 18:19:49] |
| cuckiecheese - Posts: 119 |
Hi, Is it possible to cancel only non-attached limit orders? For example if I get filled on a position that then has attached orders, I want to cancel other open orders that aren't related to my open position. Thanks |
| [2025-04-30 19:19:00] |
There is not a specific item to cancel "Non-Attached Limit Orders". But, there are Keyboard Shortcuts and Control Bar options for the following: - Cancel Buy Orders - Cancel Sell Orders From what you describe, it sounds like this should work for what you are doing - although you have to select the correct one depending on the type of position you are in (long or short) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
