Date/Time: Wed, 25 Nov 2026 21:55:58 +0000
MES v MCL
View Count: 583
| [2025-04-30 16:28:27] |
| User487766 - Posts: 2 |
Hi When I place a trade on MES, the Brackets I have show the P&L when I move the SL and TP lines up and down on the chart. However when I do the same on MCL, it does not show? Any idea please why this could be? Many thanks |
| [2025-04-30 17:10:36] |
Refer to the following setting: Global Trade Settings Windows: Attached Order P/L When Modifying (Global Settings >> Chart Trade Settings >> Working Orders >> Working Orders - Display) But this setting is global, so it would apply to all charts. Therefore, the only way this would be the case is if you are using different instances for these symbols. Is this the case, or is this occurring within a single instance? For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
