Date/Time: Wed, 25 Nov 2026 22:08:09 +0000
Theming/Color scheme issue - Change chart dom red slider
View Count: 615
[2025-04-29 20:08:26]
zakissimo - Posts: 4
I went through every graphic setting and changed every red color to make sure I didn't miss anything.
It seems like it's not possible to change the color of that slider (See attached file).
But I note that the same 'slider' used to resize chart regions is recolor-able by changing the 'Region Dividing Line' color.
Did I miss a setting ?
Date Time Of Last Edit: 2025-04-29 20:09:14
image2025-04-29_22-02.png / V - Attached On 2025-04-29 20:03:51 UTC - Size: 2.02 KB - 302 views
[2025-04-29 21:06:22]
You did not miss it. That particular color option is not changeable. It is set to red within the software.
