Date/Time: Wed, 25 Nov 2026 21:55:53 +0000
Display Prices in Sync Across Chart
View Count: 645
| [2025-04-29 15:52:24] |
| User971006 - Posts: 3 |
Hi, My requirement is to view prices in Sync across the NumberBars Chart, DOM and CandleStick Chart. I understand this requirement is already answered, I don't know the correct Keyword/Terminology to search for this feature. Also the price should be centered and charts should move up/down. Attached SC for reference. Please let me know. - Keshav |
| Attachment Deleted. |
| [2025-04-29 18:51:25] |
You would need to use the "Linking" options for charts and specifically enable the "Vertical Scale". Refer to the following: Chart Settings: Chart Linking >> Vertical Scale (Chart >> Chart Settings >> Linking menu) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2025-04-30 15:26:21] |
Thanks John, that's sorted. One more question. with this linking, when I replay the chart will I be able to replay all the 3 windows(FootPrint. DOM, CandleSticks) in sync? I have enabled save DOM data option. I know I can replay them individually, but can I replay in the exact ChartBook setup? |
| [2025-04-30 17:00:07] |
There are two options for replaying multiple charts. Refer to the following: Replaying Charts: Charts to Replay For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
