Date/Time: Wed, 25 Nov 2026 21:55:55 +0000
Volume by price
View Count: 1363
| [2025-04-28 16:51:55] |
| User247427 - Posts: 4 |
How can I see the volume for the last day in volume by price, as it now shows only today's volume? And even if I choose visible bars, the volumes change from time to time and it is necessary to show the fix scale for that day how to do it ?
| [2025-04-28 17:34:13] |
If you want to see a Volume by Price profile for the previous day, then setup the study for what you want to see, in general, and then set the Input for "Number of Periods Back to Reference" to "1". Refer to the following: Volume By Price Study: Number Of Periods Back To Reference If you are wanting something else, then we need more information on what exactly you are wanting to do. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2025-04-29 15:11:33] |
I didn’t find number of period back in indicator volume by price you can show screen exactly title this input or number example (in11)
| [2025-04-29 18:33:33] |
The location of each Input exactly matches where it is located in our documentation. So the "Number of Periods Back to Reference" is the 2nd item from the top in the list of Inputs for the Volume by Price study.
| [2025-04-30 12:05:19] |
Why cancel this when I click number 1 automatically back to 0
| [2025-04-30 15:48:24] |
You have something setup in your Volume by Price study that does not allow it to look back to previous periods. This would be items like a Volume by Price that is tied to a TPO profile, or a Volume by Price that has the "Volume Graph Period Type" set to an item such as "Visible Bars".
