Date/Time: Wed, 25 Nov 2026 22:08:10 +0000
Glitchy scrolling
View Count: 862
[2025-04-28 11:15:58]
User572037 - Posts: 41
When zoomed out trying to explore PA and do TA, the charts have a mind of their own and jump all over the place.
Is there a fix to this, is very frustrating.
Thanks.
[2025-04-28 11:17:23]
Seems to fix it if I reduce my mouse sensitivity
[2025-04-28 14:41:54]
We do not understand this. And it sounds like it is your input device that is causing the problem.
Are you using the TPO Profile Chart or Volume by Price studies?
Date Time Of Last Edit: 2025-04-28 14:42:23
[2025-04-28 15:21:18]
It is predominantly when I scroll back to review price.
This is on just normal bar charts, as well as micro studies.
[2025-04-28 15:25:47]
Reset the scale and set it to Automatic if it is not already:
Chart Scale and Scale Adjusting: Chart Bars or Studies Not Completely within View, Not Displayed, or Cut Off. Reset Scales.
Date Time Of Last Edit: 2025-04-28 15:27:25
[2025-04-28 15:29:43]
That's fixed it - Thanks
