Date/Time: Wed, 25 Nov 2026 22:08:11 +0000
Cumulative delta chart can not be established bellow the candlestick chart and VWAP chart
View Count: 722
| [2025-04-28 06:44:20] |
| User311333 - Posts: 2 |
Hello, Please advice why I can not set up cumulative delta chart below the candle stick and VWAP chart. After settings completed, no scale and cumulative delta chart is visible. I checked colors and backgrond. It is not the same color. Please find attached link to chart window screenshot. Thank you Kind Regards, Marko https://www.sierrachart.com/image.php?Image=1745822495153.png |
| [2025-04-28 16:55:38] |
Where are you getting that data from? We do not have intraday data for The ICE. We think that wherever you are getting that data from, it does not include the Bid and Ask information in order to give you the delta values. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
