Date/Time: Wed, 25 Nov 2026 22:08:05 +0000
Text Tag Keeps Removing
View Count: 636
| [2025-04-27 19:05:20] |
| user_xyz - Posts: 529 |
Text Tag no longer persistent. I noticed at various times the Text Tag is getting removed. One example is when you hit Play on Replay Chart. At least through last couple of versions and just tested on 2756, still see bug. Date Time Of Last Edit: 2025-04-27 19:41:13
| [2025-04-28 05:14:56] |
| Sierra_Chart Engineering - Posts: 25483 |
There definitively is not a bug here. What can cause the Text Tag to change: - Changing Trade Window Configuration - Using Trade Window linking. When a source Trade Window Text Tag changes, it will change on other linked Trade Windows. - Using ACSIL function sc.SetTradeWindowTextTag - Using the Spreadsheet System for Trading study and setting the Input SUPPORT_TRADING_TEXT_TAG to Yes. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2025-04-28 05:15:20
| [2025-04-28 08:00:25] |
Thanks this was it. I interpreted from the study check this as yes to use the attached order, text tag set in the Trade Window. Using the Spreadsheet System for Trading study and setting the Input SUPPORT_TRADING_TEXT_TAG to Yes.
I was also noticing making changes in the Trade Windows Config was clearing it. |
