Date/Time: Wed, 25 Nov 2026 22:08:10 +0000
FRACTIME and TIME issue or problem in spreadsheets?
View Count: 663
| [2025-04-27 17:56:31] |
| user_xyz - Posts: 529 |
I was running a 'quick' test and naturally selected a TIME that didn't work so spent hours only to find out this formula or the data has some quirks that yields inconsistent return values. Chart with 1 min candles so A3 = 2025-04-25 13:57:00, etc. =IF(FRACTIME(A3)=TIME(13,57,00), 1,0) -> Returns 0 =IF(FRACTIME(A4)=TIME(13,56,00), 1,0) -> Returns 1 (as expected) =IF(FRACTIME(A5)=TIME(13,55,00), 1,0) -> Returns 1 (as expected) =IF(FRACTIME(A127)=TIME(11,55,00), 1,0) -> Returns 0 Thought maybe related to milliseconds but helper column shows milliseconds at 0.000 I started with 11,55,00 which Returned 0 and led me down this path. Also 12,55,00 and 13,55,00 Return 1 as expected. Date Time Of Last Edit: 2025-04-27 18:26:20
| [2025-04-27 18:24:32] |
I should mention in the examples above when 0, if I SUM all values in column it is 0. Odd. (13,57,00) -> Sum of thousands of rows = 0 (13,56,00) -> Sum of thousands of rows = 397 (13,56,00) -> Sum of thousands of rows = 397 (11,55,00) -> Sum of thousands of rows = 0 Date Time Of Last Edit: 2025-04-27 18:28:05
| [2025-04-28 01:16:15] |
| Sawtooth - Posts: 4362 |
You are seeing floating point imprecision. Round down the FRACTIME to a 1 second multiple using the FLOOR function: This will produce TRUE: =FLOOR(FRACTIME(A3),1/86400)=TIME(13,57,00) |
| [2025-04-28 08:05:06] |
That worked thanks!
