Date/Time: Wed, 25 Nov 2026 22:08:16 +0000
Vol at Price Threshold Alert V2
View Count: 867
[2025-04-27 00:15:48]
Crtfyd - Posts: 310
I cant seem to get this study to work.
This is what I'm trying to do:
I want an alert when there's a Volume at Price of 30x0 (30 or more met as threshold)
So I chose the Vol at Price Threshold V2 (I have Volume by Price Study on my chart with Volume Profiles and POC, and Multiple Profiles Based...)
I can get 30+ Bid alerts by selecting "Ask Vol Bid Vol Difference" and setting the Vol Threshold at "-30" (and vise versa for Ask) no problem.
I can get Bid Volume alerts at 0 by selecting "Bid Volume" and setting the Vol Threshold at "0" (and Vice Versa for Ask) no problem.
All separate instances of course.
What I CAN'T figure out is how to combine them for one alert for 30 Bid or more, with Ask = 0 (30x0)
Ive read the instructions several times but cant get it to work.
I select "Bid Vol Ask Vol SEPARATELY" and (for Bid) Vol Threshold at -30,
THEN "Additional Volume Threshold at 0.
With that configuration, Ive tried all options and cant get it to work.
Ive Enabled the Zero for yes and No,
Zero Value Compare Action to "Set 0 to 1", and pct 1,000%
Still cant get it to work.
I don't know if its possible, because as the Bid can be 30 or more, but the Ask has to be zero.
I think I saw that setting it to zero disables it, but I don't want 1 or more ASK.
Ive set all with separate instances, but it just clutters and cant be read fast enough instead of a simple alert for 30 (or more) BID and zero ASK (30x0)
Can this be done?
btw, yes I can see a 30x0, and 42x0, etc, so I know they're there.
Also this is on a Number of trades of 100 chart.
