Date/Time: Wed, 25 Nov 2026 22:08:02 +0000
Start Replay from Date-Time Bug?
View Count: 782
| [2025-04-26 23:33:08] |
| user_xyz - Posts: 529 |
1 - I have Start Replay from Date-Time on right click shortcut menu which brings up the Replay Chart Control Panel. Accessing via this method does not prompt for Clear Trade Data Options when starting replays. If I access via menu or Ctrl-R to bring up Replay Chart Control Panel, the Clear Trade Data Option appears. 2 - Is there a way/setting to run through replays of intraday bars where session time set to say 9:00 - 9:15 est. So 15 min chunk of each day. Chart shows 15 min candles during that time period each day with no gaps, however in Replay Chart Panel using methods Time, To Next Bar or To Next Time Increment the replay is processing weekend data. To Next Bar is doing what I would expect but there is like a 1 minute delay over weekend timeframes. Skip empty periods is checked. Date Time Of Last Edit: 2025-04-27 03:19:18
| [2025-04-28 15:54:29] |
1. What you are seeing is the way the functionality works if you select "Chart >> Replay Chart >> Play/Pause". Either method does not ask to clear the data. 2. We are not really understanding the situation you are trying to describe. You are trying to replay over a 15 minute period, so how does the weekend fit into this? For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
