Date/Time: Wed, 25 Nov 2026 16:39:10 +0000
[Programming Help] - Large Volume Trade Indicator: Source code
View Count: 3105
| [2025-04-26 18:17:21] |
| User509533 - Posts: 99 |
Could you please tell me which file in the ACS_Source directory contains the code for the Large Volume Trade Indicator? I have already searched through Studies.cpp to Studies8.cpp. Large Volume Trade Indicator Date Time Of Last Edit: 2025-04-27 01:49:25
| [2025-04-28 15:23:07] |
The source code for the "Large Volume Trade Indicator" is not available. Refer to the following: How to Build an Advanced Custom Study from Source Code: Source Code for Some Built in Studies Not Available For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2025-10-28 21:59:10] |
| User688525 - Posts: 403 |
Hi John, If trying to build a similar study to the Large Trade Volume Indicator in ACSIL, would the DRAWSTYLE_TRANSPARENT_CIRCLE_VARIABLE_SIZE be used to plot a transparent circle that looks the same as the "bubbles" in the Large Trade Volume Indicator? If yes, and the variable size of the circle is controlled by the Width input, how can the same level of granularity (1-100) be achieved for the variable size? Thank you Date Time Of Last Edit: 2025-10-28 22:08:05
| [2025-10-28 22:08:23] |
If you are wanting to have different sizes for the "bubbles" based on the volume, then this will not work, as there is no support for different sizes for each subgraph at each index, like there is for colors. Refer to the following for colors to understand what we mean if you are not familiar with it: ACSIL Interface Members - sc.Subgraph Array: sc.Subgraph[].DataColor[] We have set this as Programming Help, as others may be able to give you ideas on how best to approach this. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2025-10-28 23:01:00] |
Thank you for confirming.
