Date/Time: Wed, 25 Nov 2026 22:08:12 +0000
[Programming Help] - What version check to do for an ACSIL study?
View Count: 844
| [2025-04-26 03:29:48] |
| LTSys2 - Posts: 29 |
I noticed a couple places to get a version number in the SC API. If I want to share my study that I built on SC version 2744 and I give it to someone who might be running an older version of SC how would I do that check in the code? This one... if(atoi(sc.VersionNumber().GetChars()) != 2744) return false; Or this one... if(sc.ACSVersion != 2744) return false; TIA Date Time Of Last Edit: 2025-04-26 03:30:50
| [2025-04-26 15:13:59] |
| ForgivingComputers.com - Posts: 1256 |
You won't be able to load a DLL built with a newer version onto a previous version. You can name your files with minimum version supported, so you can support both versions: My_Study_2739.cpp
and My_Study_2744.cpp
| [2025-04-26 18:14:26] |
Thanks for clarifying.
