Date/Time: Wed, 25 Nov 2026 22:08:17 +0000
Instant Dom Recentre After Certain Amount Of Ticks
View Count: 807
| [2025-04-24 21:16:23] |
| User528294 - Posts: 10 |
Is it possible to have the dom/price ladder recentre instantly after a certain amount of ticks instead of scrolling recentre?
| [2025-04-24 21:46:01] |
You need to set the "Adjust Interval" to a value of 1. Refer to the following: Chart Scale and Scale Adjusting: Constant Range Scale Modes >> Re-Center When The Last Bar Exceeds A Certain Number Of Ticks From The Center For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
