Date/Time: Wed, 25 Nov 2026 22:08:11 +0000
Text on Rectangle TC
View Count: 674
[2025-04-24 15:58:10]
User98657 - Posts: 420
SC,
I am able to draw a rectangle and assign a Tool Configuration. However, the text that I've added to the Rectangle is not being saved as part of the TC.
Extending Rectangles do hold the text as part of the configuration, so I'm not sure why the Rectangles would not.
Can you advise?
Thanks.
[2025-04-26 14:03:45]
SC,
You can disregard. I'm now able to see the Copy Tool Config Name To Text on certain Drawing Tools. For whatever reason, perhaps you've made some changes, I am able to see it now after finding it in the Global Settings.
[2025-04-26 14:44:55]
As I said, I found the Copy Tool Config Name To Text input in Global Settings. Ellipse Config has that input, but Text does not appear to be an attribute available to this Drawing Tool.
The name is applied to the Tool Config, but not assigned to the Drawing.
Can you please advise?
[2025-04-28 15:02:23]
The Ellipse does not have support for any text to be associated with it.
