Date/Time: Wed, 25 Nov 2026 21:56:05 +0000
Does Sierra Chart currently support Eurex market data in addition to CME together?
View Count: 1772
| [2025-04-23 23:06:06] |
| User480109 - Posts: 59 |
I currently have market data for CME, CBOT, but also would like to have EUREX. I remember in the past Sierra Chart once did support Eurex but took it off. What is the latest on this feed?
| [2025-04-24 06:15:59] |
| Sierra_Chart Engineering - Posts: 25483 |
Yes EUREX is supported.: https://www.sierrachart.com/UserControlPanel.php?page=DenaliDataFeedEUREX EUREX was never removed. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2025-04-24 09:29:23] |
is there a symbol list for major eurex symbols like german bunds, fesx etc that sierra chart uses?
| [2025-04-24 10:01:35] |
| User135243 - Posts: 337 |
File, Find Symbol and there Futures-Eurex |
| [2025-04-24 10:07:06] |
My apologies, I did not meant to ask about EUREX, it was ICE-EU feed that I think once Sierra Chart had but did not provide anymore. What is the latest on getting ICE connectivity?
| [2025-04-24 14:47:55] |
This is correct - we did have ICE data at one point but we do not any further. You would need to see if you can get The ICE data from your trading service. Another option would be DTN IQ Feed, as we have connectivity with them for data. Refer to the following: DTN IQ Feed Data Service For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2025-04-24 21:12:58] |
If I choose to have DTN feed, how would that work with current Deanali feed for CME and EUREX? Can SC support two connectivity in one instance?
| [2025-04-24 21:42:55] |
Sierra Chart is specifically setup to allow you to get data from us while connected to another service. So you can get The ICE data from DTN as well as receiving the CME and EUREX data from our Denali Exchange Data Feed. But, you will not be able to connect that installation to a trading account, as you are connected specifically to DTN. In other words there is no way to get data from DTN and connect to a trading service to trade those symbols. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2025-04-29 15:56:54] |
Hey John- That sounds great, in service settings, do I point to DTN's IQFeed? I assume that with this setup, the SC feed is inherited and like you say, can use symbols from both. |
| Attachment Deleted. |
| [2025-04-29 18:56:47] |
This is correct. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2025-05-06 17:50:41] |
Hey John- I tried to point to DTN feed like you suggested and I do see the ICE symbols updating. However, when I went to my other chartbook with CME symbols, they stopped updating. There was a red error box that basically said symbol not recognized. Can you help |
| [2025-05-06 19:11:41] |
You need two installations of Sierra Chart one for SC Data - All Services. And another installation for IQ Feed. Refer to: Using Multiple Data and Trading Services at the Same Time You cannot access data from the Denali Exchange Data Feed when using IQ Feed. That will not work right. Anything communicated previously regarding this, was not correct or was based upon a misunderstanding. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2025-05-06 19:11:59
