Date/Time: Wed, 25 Nov 2026 22:08:02 +0000
Create Custom Control Bar Buttons for Specific Attached Order Configurations (Bracket Orde
View Count: 1050
| [2025-04-22 16:21:42] |
| FantomasX - Posts: 1 |
Hi Sierra Chart Support, I would like to set up individual Control Bar buttons on my Stream Deck that each submit a different Attached Orders configuration (e.g. different step trailing stop brackets) directly from the chart. For example: - One button to execute a Buy Limit order using the `20T-2TargetsWithStepTrailStop` configuration - Another button for `40T-2TargetsWithStepTrailStop` - Etc. Each bracket is already saved in the Trade Window dropdown, and I use them manually by selecting and placing orders. Now I want to place them with a single click, without needing to change the configuration each time whit the Mouse. Is there a way to: 1. Create custom buttons that reference a specific saved Attached Orders configuration? 2. Assign those to the Control Bar (or through hotkeys)? 3. Or alternatively: Use ACSIL to set the config and execute the order? Any help or code snippets would be much appreciated! Thanks in advance |
| [2025-04-22 17:22:27] |
Within Sierra Chart, you can setup Control Bar buttons for different Trade Configurations and you can then setup Keyboard Shortcuts for those control bar buttons. Refer to the following: Control Bar: Control Bar Trade Window Configuration Buttons If you want to do this through ACSIL, then refer to the following: Automated Trading From an Advanced Custom Study: Programmatically Setting Trade Window Configuration For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
