Date/Time: Wed, 25 Nov 2026 22:08:06 +0000
Problem with closing position
View Count: 661
| [2025-04-22 15:54:47] |
| User811567 - Posts: 8 |
If I have 3 different CL positions open, when I want to close the third one opened in a row, the first one that was opened the earliest closes. Why?
| [2025-04-22 16:49:18] |
| User135243 - Posts: 337 |
it seems you don't know how the exchange works, the exchange works with the FIFO (first in, first out) principle
| [2025-04-22 17:32:03] |
The order in which a position is closed out really does not matter, as it all works out in the end. But as noted, the exchange uses a FIFO methodology, and, by default, Sierra Chart displays the trades in this method. You can change how the orders are matched using the following setting: Chart Settings: Use Last In First Out Fill Matching (Chart >> Chart Settings >> Trading menu) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
