Date/Time: Wed, 25 Nov 2026 22:08:16 +0000
[User Discussion] - Is anyone using Spreadsheet Studies on Linux/Ubuntu?
View Count: 841
| [2025-04-21 15:19:11] |
| C_Money - Posts: 90 |
I realize SC doesn't support Linux distros using Wine. I do find it works flawlessly but with one issue: When trying to expand the cells in to a bigger box in Spreadsheet Studies, the window opens and rapidly closes before you can do anything. I found this has to do with the Window Manager inside the Wine configuration. When you turn uncheck "Allow the window manager to control the windows", the cell will open and you can drag it around. But keep it checked, and it just closes. Has anyone found a workaround for this? Without the Wine window manager, all my SC windows are basically hidden and I have 4 monitors and 8 chart windows. Even hitting the Windows key that would normally show me all the windows I have open and bring one to my view doesn't show them. |
| [2025-04-23 20:35:44] |
I'm wondering if there is a way to find out what windows libraries SC is using to pop out the cells from spreadsheet studies? Do any SC devs know?
