Date/Time: Wed, 25 Nov 2026 22:08:12 +0000
Volatility-adjusted (ATR) Renko charts
View Count: 1462
[2025-04-18 18:33:55]
User14953 - Posts: 268
Can Volatility-adjusted (ATR) Renko charts be manually implemented in Sierrachart - Automatic adjustment using Average True Range calculations
Date Time Of Last Edit: 2025-04-18 18:41:09
[2025-04-18 19:18:31]
Refer to the following for the only possible way that this could be done:
ACSIL Interface - Custom Chart Bars
[2025-04-19 18:09:11]
User61168 - Posts: 491
coincidentally even I am looking for variable brick size renko chart (preferably based on spreadsheet formula study which then could be coded for ATR or any custom calculation). Is there a 3rd party solution available out there? also/is the ASCIL code for delivered Renko charts available to SC Users to tweak/modify?
[2025-04-21 13:01:26]
gtaranti - Posts: 99
Yes, as User61168 says..!
Having the ACSIL code for Renko charts as a template for a custom chart bar would be very useful!
