Date/Time: Wed, 25 Nov 2026 22:08:12 +0000
[Programming Help] - Recalculate target study only
View Count: 832
| [2025-04-18 17:23:24] |
| User200641 - Posts: 8 |
I am attempting to use study A to modify the inputs to study B. I can see that the inputs to study B are being modified correctly but the updates don't take place. When sc.RecalculateChart(sc.ChartNumber); is added, study A is also also recalculated, which then re-triggers the chart recalculation, which recalculates study A, etc. etc. My chart freezes until the study is removed. Is there "sc.RecalculateStudy()" function equivalent where I only recalculate study B? Or perhaps a better way to handle updating other study inputs? Thanks |
| [2025-04-19 19:13:22] |
To anyone reading this in the future: I was able solve this by wrapping the recalculation portion of my study code in the simple if statement below: if(!sc.IsFullRecalculation)
{ // Your recalculation code here e.g.: sc.RecalculateChart(sc.ChartNumber); // Also can wrap anything else you don't want run during recalculation here } |
| [2025-04-19 21:57:09] |
| Sierra_Chart Engineering - Posts: 25483 |
It is not possible to calculate a single study. They all must be calculated at once and in the appropriate order.
