Date/Time: Wed, 25 Nov 2026 22:20:51 +0000
Order Quantity Buttons in Control Bar
View Count: 953
[2025-04-16 15:54:21]
TraderBiku - Posts: 41
I recently added order quantity buttons to the control bar on my chart, but in addition to the customizable button caption, each of the buttons has a parenthetical value (which appears to correspond to the value assigned to the quantity button) appearing on a separate row from the button caption, making the buttons "taller" than necessary (ie making them 2 lines of text "tall") - is there a way to either have the parenthetical value removed, or to allow for a blank caption which shows only the parenthetical value, since these "taller" buttons are taking up extra screen real estate - all my other button captions are one line in height.
Thank you -
[2025-04-16 18:16:15]
There is not a way to remove both lines. You can change the "Caption:" to be whatever you want, even a single digit (i.e. "1", "2", etc.), but the second row with the actual quantity value set for that button will always be displayed.
The only way to change this would be to use an image instead of the caption. Refer to item #10 at the following:
Control Bar: Control Bar Button Properties
There is also the option for "Use Same Size for Control Bar Buttons". Refer to the following:
Control Bar: Use Same Size for Control Bar Buttons
