Date/Time: Wed, 25 Nov 2026 21:55:57 +0000
Bollinger Bands restart calc at session open
View Count: 701
[2025-04-16 13:44:00]
User512353 - Posts: 198
When using the Bollinger Bands study, when the chart is set to display only the RTH session, there usually is a large gap between the last bar of the previous session and the first bar of the current session. This causes the Bollinger Bands study to display a huge spike.
Is there any way to force the Bollinger Bands study to simply restart the calculation at the beginning of a RTH session, ignoring any previous session, and thereby avoiding the typical spike at session start?
[2025-04-16 17:55:56]
The Bollinger Bands is not setup to "start" at a particular time. It uses a Length Input to determine how far back to get the data. Therefore, what you are seeing is how this is going to work.
You could modify the code for the study to not calculate until the number of bars is met at the start of the day. The source code is in the Studies3.cpp file. Refer to the following:
How to Build an Advanced Custom Study from Source Code
https://www.sierrachart.com/index.php?page=doc/SierraChartStudyAndSystemProgrammers.php
[2025-05-02 15:52:32]
User763335 - Posts: 133
Hi, I have this issue with a couple of different studies as well..,that are based on length(eg 10 period moving average).
For those charts covering only the RTH session(9:30AM-4pm EST for Equities), I'd like to have these studies, start plotting only from the Session start time.
Are you able to offer any assistance in adjusting my studies or recommend contacts for such code edits?
[2025-05-02 18:42:34]
