Date/Time: Wed, 25 Nov 2026 22:20:55 +0000
Spreadsheet
View Count: 650
| [2025-04-16 01:00:04] |
| User98657 - Posts: 420 |
SC, I wanted to set up a spreadsheet to provide Max values, and average values for a ZigZag subgraph. The problem is, in order to capture all of the values, I need to set the SS to some ridiculous number of rows that will just make it impossible to run. However, I thought I might be able to change the SS Study "Based On" input to the ZigZag Study and "hopefully" only have the line length come through to the SS. And it did do that, however it also brings in all of the bar data as Subgraph values, and I'm back to the same problem. Is there anyway to exclude the bar data from the spreadsheet? |
| [2025-04-16 17:17:41] |
There is no way to remove the bar data from the Spreadsheet Study.
