Date/Time: Wed, 25 Nov 2026 22:20:46 +0000
Im stuck on getting ntfy to work with ios
View Count: 820
[2025-04-15 02:13:12]
mrchet - Posts: 25
I have followed the instructions a couple of times. I searched and I just can't figure out what Im doign wrong.
I had telegram working, if that helps.
Does it matter than the sierra chart chat still talks about sending messages to telegram? If that is the issue how do I update the chat software.
If I set an alert it triggers and gets copied into the sC chat window. I tried to set up ntfy on my ios device. I never get any chats relayed to my phone.
[2025-04-15 05:05:22]
Sierra_Chart Engineering - Posts: 25484
You are running an up-to-date version of Sierra Chart and here are the relevant instructions:
Chat and Communications Platform: Integration with Mobile Ntfy Application
Follow through the instructions here and make sure you are at least getting the chat messages within the ntfy app web application:
Chat and Communications Platform: Using Ntfy Web Application
Date Time Of Last Edit: 2025-04-15 05:06:54
[2025-04-15 21:06:06]
There is a known issue with Chat connection to nfty on a MAC using emulator software.
